Upping compression on P1SC setup
Old May 17, 2010 | 12:33 PM
wakesk8te's Avatar
Default Upping compression on P1SC setup
I was just wondering. If you plan on going into a motor, would it be a good idea to up the compression on a 346 if you only plan on running a P1SC Procharger setup?
I was thinking about getting the most efficiency out of the P1SC.
Old May 17, 2010 | 01:52 PM
rich5368's Avatar
From everything I've read 8psi on stock 10.1:1 cr is about the limit. So in theory if you raise to higher compression you're reducing the amount of boost you can use on the stock bottom end. If anything I'd drop compression and raise boost. Get more power in the long run that way.
Old May 17, 2010 | 06:32 PM
-Q-'s Avatar
-Q-
There are plenty of people running more than 8psi on a stock motor. Personally, I'd draw the line at 10psi, but I've seen people on here running 12-13 and live to tell about it. A good meth setup would definitely be your friend, though.
How much boost do you want to run with the P1?
