Over heating at stop lights
Old May 17, 2010 | 06:55 PM
stngtamr29's Avatar
Default Over heating at stop lights
Hey guys my car seems to be running upwards of 235 degrees on hot (90 degree) days when Im stopped at a light or in slow traffic. My question is do I need to upgrade from the fan and shroud that Procharger sent and maybe go with two 12inch pushers? It will run hot with or without the ac thanks
Old May 17, 2010 | 07:21 PM
Packy's Avatar
I had some similar problems to you. I just changed to 90% Water/10% Anti-freeze and switched my 16" ATI supplied fan out for a new Spal (30102082) 16" fan. That took away all of my problems like that that I had. It is back to running around 175 to 190 degrees depending on the ambient temp. outside and if i have the AC on it might go up to around 200 or so if I am in a standstill.
Old May 17, 2010 | 07:41 PM
stngtamr29's Avatar
Where did you buy yours and will it mount in the same holes or do I need the mounting hardware Thanks
Old May 18, 2010 | 02:08 PM
Bad30th's Avatar
You can upgrade the 16" fan and install an additional 9" SPAL fan on the shroud (which is what I did).
I also switched to the SLP (LT1) radiator.
Rob (Bad30th)
Old May 18, 2010 | 04:37 PM
Aster's Avatar
The Spal fan 30102082 does not mount to the existing holes if I remember correctly. I am pretty sure I drilled new ones when I installed mine. It was not difficult at all though.
Old May 18, 2010 | 07:06 PM
stngtamr29's Avatar
Hey thanks guys I ordered the fan (30102082) and if still runs to warm ill add another smaller fan on the other side thanks
Old Mar 12, 2012 | 08:55 PM
stealth355tpi's Avatar
bring this back, about to buy the same fan. anyone having any issues with the spal 30102082? also i see it draws 22amps. how are you wiring this, stock wires or with a relay? thanks.
Old May 27, 2012 | 11:53 PM
4kiro's Avatar
Others think the water pump might be bad. Wondering if switching the fans worked. How did you guys do the wiring.
