Need air to water intercooler advice.
Old May 17, 2010 | 08:12 PM
DomesticAbuse's Avatar
Default Need air to water intercooler advice.
Hey guys, I'm trying to get opinions on what size -AN line I should use for my air to water setup. I have a meziere electric water pump that flows 20GPM. What would be the ideal hose diameter to support 1000+rwhp? Any help or advice would be greatly appreciated. Thanks
Old May 17, 2010 | 09:48 PM
OUTLAWZ RACING's Avatar
-8 or -10
Old May 17, 2010 | 11:23 PM
355TurboLT1's Avatar
Go with atleast a -10. Depending on how long your run is you want to be able to move some water.
Old May 17, 2010 | 11:33 PM
onfire's Avatar
Coal Mining Director
16an on mine.
Old May 17, 2010 | 11:47 PM
lazylongboarder's Avatar
-10 for long runs or a weak pump, -12 for a great pump and moderate runs with a good size exchanger, -16 with tandem pumps or short runs or no exchanger.
Old May 18, 2010 | 07:16 PM
Fk i dident know they came that big lol I go with a -16 and a wicked rule pump.
Old May 18, 2010 | 07:50 PM
Thanks for the advice guys. Since I just bought 70ft of -10AN for my feed, return, and catch can lines I guess I'll use -10AN for the A/W lines as well. I also have a big fluidyne heat exchanger in front of my radiator that the water will be passing through as well. I just didn't want to go too big because I was affraid I would lose some line pressure and then the water wouldnt flow as fast. Any other info is still welcome.
