Post up your turbocharged engine bay!
Old May 25, 2010 | 01:37 PM
  #61
XtremeDime's Avatar
Why are you running 2 wastegates on a single tubo?
Old May 25, 2010 | 02:09 PM
  #62
koolrayz's Avatar
Originally Posted by helicoil
Any feedback on this system, been eyeing it for awhile. Getting close to making a decision. I haven't seen many who have it. Looks like they do high quality work which is a plus. Always wondered why the header configuration is different from side to side? How did that GT55 do for you thru the air to air? Was that on a 346" engine?
There work is outstanding, they are just not known in the LS world yet. After the Hot Rod Magazine car is done that will all change. The main reason headers are different because you need top access to the passenger side for plugs driver side is a cake walk from the bottom. The air to air really surprized me. I see 5 to 15* over ambient on the intake temps. Last year the engine was a 410ci. I had an oiling issue that ended my season before I had a chance to lean on it. This year I have an ERL block and a dry sump so I hope to find the limits of this turbo. I think this system would be even better with the GT55 106. I just dont have the money for another turbo right now.
Old May 25, 2010 | 02:22 PM
  #63
dreamls1's Avatar
Old May 25, 2010 | 02:23 PM
  #64
czwalga00gt's Avatar
Why not? I mean aside from why I actually am there's no reason not too for added assurance, other than the money end...
However, the main reason I am is because I like to do some road racing and I will swap the springs to run like 3 psi, instead of 15. No way in hell I could go that low on a single mv-s wastegate.
Old May 25, 2010 | 03:35 PM
  #65
ERL Performance's Avatar
Ray, great looking setup. I hadn't seen your setup until now. Ron's kit looks pretty good too.
Old May 25, 2010 | 06:31 PM
  #66
jay_rich's Avatar
Almost finished, May put a 90 on the wastegate and move it for ease of changing springs, and have to coat/wrap the headers still.
Motor is being sent out (this is just mock up thats why its all grimmy)
Car is an 1987 Iroc-Z
Jay
Old May 25, 2010 | 06:36 PM
  #67
koolrayz's Avatar
It is going to look a lot better with that KICKASS block you did for me
I pick the engine up from Kurt this week
Old May 25, 2010 | 08:41 PM
  #68
helicoil's Avatar
I figured it was for plug access, but aren't both sides accessible from the bottom? Was last year a 4-bolt set-up? I assume this year is a 6-bolt Superdeck 1. Nice combination of parts, all quality. Top notch builder too. This looks like a real nice build. What are the expectations?
Old May 25, 2010 | 09:48 PM
  #69
griprus's Avatar
Restricted User
some very nice setups
Old May 25, 2010 | 09:51 PM
  #70
griprus's Avatar
Restricted User
Default single front mount
here is a couple pictures of front mounts i done
Attached Thumbnails Post up your turbocharged engine bay!-5_dp_1.jpg   Post up your turbocharged engine bay!-turbo-kit.jpg
Old May 26, 2010 | 06:53 AM
  #71
koolrayz's Avatar
I got the 6 bolt super deck but I have to wait until this winter to get the 6 bolt heads I want. I really just want to be able to run the local 8.90 index classes consistantly without stressing the setup. I only have an 8.50 cert on the chassis so I wont be able to run faster than that many times without getting in trouble with the track.
Old May 26, 2010 | 07:15 AM
  #72
helicoil's Avatar
I know this stuff is awfully pricey. What did you have tied up in your turbo set-up? 8.90's is a quick street car. You can PM on the price if you'd like. Is the set-up street driving friendly, I was curious with turbo placement if it pulled all the hot air in off the radiator. BTW, do you have a recipe for the radiator install?
Old May 26, 2010 | 07:18 AM
  #73
performinnorman's Avatar
Great lookin engine bays. I'm not even going to bother posting a pic of mine as my turbos sit in the fenderwell and the engine bay looks stock.
Old May 26, 2010 | 08:11 AM
  #74
CarsandWomen's Avatar
another reason is that you must mount the WG so that it bleeds off exhaust from both banks of cylinders, if it doesnt then you will see massive boost creep. the bank with the gate will all go out the gate, and the bank without will all go through the turbo.
you can mount the single gate at or after the merge, OR, use pipes to mount a single gate to both banks, OR, run two gates.
Old May 26, 2010 | 12:00 PM
  #75
Hugger Z's Avatar
I was debating that too. But here is mine. Cell phone pics in the garage so not the best lighting.
Attached Thumbnails Post up your turbocharged engine bay!-2010-05-14-22.04.26.jpg   Post up your turbocharged engine bay!-2010-05-16-21.29.16.jpg
Old May 26, 2010 | 01:06 PM
  #76
Phil99vette's Avatar
7 Second Club
Two wastegates allow you to run very low boost which in some cases is required to be able to get the car to leave with the amount of power these turbo combinations are making. Most of the single gate/non-optimal placement stuff creeps at low boost levels.
Old May 26, 2010 | 04:41 PM
  #77
biggdogg's Avatar
Old May 26, 2010 | 09:13 PM
  #78
elias_799's Avatar
^^^you have an A2W on the passenger seat ?
Old May 27, 2010 | 05:56 AM
  #79
Boosted One's Avatar
64 Chevy II
Old May 27, 2010 | 12:30 PM
  #80
Ws6kid.'s Avatar
some great post in here!
