Air Intake in trunk??
Old May 18, 2010 | 08:16 PM
JAX04's Avatar
Default Air Intake in trunk??
I dont think there would be a problem or an issue other then maybe heat, But has anyone with their rearmounts put the inlet into the truck area, I know most are Fbody, but im a gto with a real trunk,
does anyone see any issues with this, Just trying to button my setup and think that maybe this would be the best way to insure no water issues at all
Old May 18, 2010 | 08:34 PM
Ericmck2000's Avatar
Im no genious, but, you might want to pug a hole somewhere for air to get into the trunk....
Old May 18, 2010 | 08:42 PM
boosted LT1's Avatar
I have my air filter in my trunk in a Roadmaster rearmount. It works fine the volume of the trunk lasts a LONG time relative to wot...also air seeps from inside car
Old May 18, 2010 | 09:26 PM
98Z28CobraKiller's Avatar
Restricted User
How noisy is it?
Old May 18, 2010 | 09:27 PM
JAX04's Avatar
im sure its noisy, nothing some insulation in the trunk couldnt fix, behind the seats. But im not exactly worried about noise either.
Old May 18, 2010 | 10:07 PM
kikass_z28's Avatar
roof scoop with ducting
Old May 18, 2010 | 10:36 PM
When backing down it is noisy
When hitting it not so bad since the engine and exhaust is majority of sound.
Old May 19, 2010 | 04:51 PM
JAX04's Avatar
what about IATs boostedlt1??
Old May 19, 2010 | 05:20 PM
IATs weren't a problem. The air in trunk isn't baked for a week or anything. I would say the air in trunk is less than from underhood...BUT I have an FMIC and run two stage Meth M5's I think.
Car is in TN so I can't check but I think M5's are what is in there.
Old May 19, 2010 | 06:08 PM
JAX04's Avatar
i would think as long as your using meth it wouldnt really matter then, plus i have plans to run e85, so i think that the air intake in the trunk would be just fine for me
Old May 19, 2010 | 06:35 PM
Compared to water road grime etc the trunk is a fair trade off IMO
Good luck
PS meth was used for octane temps dropped maybe 10 15 f in rearmount
Old May 19, 2010 | 06:58 PM
JAX04's Avatar
is there a difference in the amount of meth u use based on what you are using it for?
Old May 19, 2010 | 07:14 PM
The percentage of methanol compared to % of water changes how it 'acts'
Like many discussions there isn't one answer all on here will accept and I don't want this to turn into an argument so I will simply say read other threads on methanol...
I have a link at work to another site that goes for many pages and compares many aspects I will send it and you can link it to your thread if you like
Old May 19, 2010 | 09:59 PM
Rossko85's Avatar
lucky bastard! get to learn from others' mistakes!! *** cake!!
Old May 20, 2010 | 07:22 AM
With a post like that how bad can my giving a link be?
http://forums.nasioc.com/forums/showthread.php?t=937176
The thread has some good information and I thought was very informative.
Good luck
Old May 20, 2010 | 05:04 PM
JAX04's Avatar
thanks guys
