PCV/Catch Can/Breather setup
Old May 12, 2013 | 10:52 PM
Br1_ss's Avatar
Originally Posted by JoshuaGrooms83
iknow, diggin lol but i have too
]So just to make sure,
i want this setup right? even if i run a rear mounted turbo setup?
I already have a catch can and check valve with an LS6 valley cover right now. IT would be advisable to run a vac line all the way back to the turbo compressor inlet source? just checking ot make sure.
Your missing the back plug for the intake manifold.
Or do you use that for the WG?
Old May 13, 2013 | 08:49 PM
JoshuaGrooms83's Avatar
lol well that has to bee hooked up regardless unless you run a differnt setup form factory. i was running the wastegate reference to the brake booster line.
Old May 14, 2013 | 01:12 AM
Eddie Aop Benjamin's Avatar
good ****
