Boost and Compression!!!
Old May 24, 2010 | 11:05 PM
greasess's Avatar
Default Boost and Compression!!!
This has been and still seems to be a hotly debated topic. How much compression can you run with a given amount of boost and octane? My goal is 1000 RWHP on 93. I'm building a 402 ls2 and i will use an 88mm turbo of some kind (probably Master Power). I'm going to experiment with my factory ls1 first to see what I can get away with. The only things I'm going to modify are pistons and rods (bending a rod or stretching rod bolts won't give me a real answer) and smooth any rough areas in the combustion chamber. I think I should start with 10 to 1 compression. Any input would be appreciated.
