5.3 Turbo ???S
Old May 26, 2010 | 03:11 PM
boosteds10's Avatar
Default 5.3 Turbo ???S
With the 5.3 and the 317 heads and a Z06 cam, how much boost would yall say would be safe or on the border line on pump gas? Im thinkin 15lbs from a MP t70 with a decent size FMIC. And what kinda power should that make to the ground through a th350 with a 2800-3200 converter and a 8.8 ford rearend with 3.27 gears?
Old May 26, 2010 | 03:26 PM
kdavis's Avatar
I wanna know to
Old May 26, 2010 | 03:32 PM
hellbents10's Avatar
LS1Tech Sponsor
12-14psi should be OK with pump gas and the 317s. I would guess about 470-500 through a loose converter. It would be 600 with a locked converter.
Old May 26, 2010 | 04:16 PM
boosteds10's Avatar
OK thanks! Now that you have opened the door on the converter subject, what converter would you recomend for the street?
Old May 26, 2010 | 04:21 PM
kdavis's Avatar
Do 4L80e put down the same power as th400s? Or more? Sorry for the threadjack
Old May 27, 2010 | 08:47 AM
boosteds10's Avatar
What year 5.3 would be the best to start with? And what the most they have held on race gas with a spot-on tune? Just curious.
Old May 27, 2010 | 09:45 AM
1320's Avatar
In the turbo aws van, it has its oem 5.3 still in it, running about 18 psi daily now on 91 octane with water / meth at 50/50. It runs 317's with a z06 cam. Its at the end of the walbro 340, and at the end of 60lb injectors. At 6500 lbs it runs high 12's at 3000 ft da at 107 mph. I think it works out to around 700 crank. It lives on the water meth and runs a giant intercooler (stock 98 12 valve ram cummins intercooler) We talked about it yesterday. I ve had two blower cars in the last month rll through that both were inthe 200 degree IAT area on a run. I have one down to 125-130 now....The other will hopefully get down to atleast the same area of maybe if I cross my fingers get lower then 100. One runs 6 psi, the other 10.5..........the van.....18 psi...61 degrees IAT at the end of a full run. Starts at 100-110, drops to 78 at the onset of water, then goes to 65 almost immediatly, then slowly goes down to 61 DEGREES.....I will never own a blower car on purpose. I know they can be fast, but what a bad design and pita.
5.3's are great.
Old May 27, 2010 | 12:23 PM
b20forlife's Avatar
Now what about with a power glide since it robs less power on pump? Also how is a lcked converse work for the steet? Sorry to tread jack
 Michael S. Palmer
Old May 27, 2010 | 01:01 PM
boosteds10's Avatar
5.3's are great.
1320, what turbo are you using and do you thing a 12v cummins IC will fit in a first gen s10? And what water meth set up are you running?
Old May 27, 2010 | 02:43 PM
1320's Avatar
That one has a turbonetics 72, 1.00 divided housing (coated). Anything will fit if your motivated enough. I doubt it but maybe with some cutting. It runs a devils own kit off the 2 bar map, (sd tune)
If you got the intercooler in there, the entire front end would be intercooler.
Old May 27, 2010 | 09:42 PM
boosteds10's Avatar
Could you possibly get me some deminsions on that intercooler? And what is the "devils own kit" and "(sd tune)"?
Old May 27, 2010 | 10:28 PM
1320's Avatar
Pm me , and Ill have a shop guy measure one of the intercoolers. I think I have two more.
Devils Own is the alcky kit name.....you can search devils own and find their web site. I ve bought enough from them now I m a dealer also. But thats not saying much, Im a dealer for most alky companies because I ve tried most of them.
Sd tune, is a tune that changes the operating system in the oem pcm and gets rid of the maf all together. The fueling changes (and timing) are based on the map sensor (boost). A 2 bar sd tune reads to 14.7 psi....and you can easily fudge above that alittle, but its way better then using the maf for fuel calculations when you can max the reading at around 4000 rpm. Everything above 4000 is a guess. With sd, it gives more tuning control when in boost.
SD is short for speed density, which was used by most oem manufacturers at some point. GM used sd on 93 f fbodys, 92-93 vettes, ford used it in mustangs etc etc....now we use it for better fuel control.
Old May 27, 2010 | 11:56 PM
1998TA__1991RS's Avatar
im running 15lbs through a ls1 with 317's and a ls2 cam on 93 octane and about 11* of timing through a th400 and 9", i have no clue what kind of power its making but it runs well at the track
Old May 28, 2010 | 07:36 AM
CarsandWomen's Avatar
i saw one guy push one to 18 psi but it saw the end of that motor very shortly thereafter. 1 Bad Ls1 runs 17psi daily on his
Old May 28, 2010 | 11:01 AM
pwrtrip75's Avatar
On my 5.3 I ran 15psi + a 50 shot of N2O. Never had a problem for 3 years.
