Volumetric Efficiency (VE), How do we calculate it???
I have Stage II heads with 2.020/1.577 valves. How do I know what my VE is in percent???? I need the percent calculation to calculate boost compression ratio.
Thanks
Thanks
Do a search in the computer section. When you do the calculations you will like seeing the VE greater than 100%. I calculated about 35% higher than stock throughout the VE table. This is for a Incon setup at 9 psig and 91 octane at 4200 ft above sea level.
Gary
Gary
Gary
Gary
