cam 232/240 .595/.609 115 work for turbo?
GM 6.0L Cast-Iron Block
Callies CompStar 4.0 Stroke LS1 Crankshaft
Callies CompStar LS1/LS2 Connecting Rods
Diamond Racing Forged Piston: 4.010 Bore, 4.000 Stroke, 6.125 Rod Length 1.115 CD, -28cc Dish, HD H-13 Wrist Pins
Texas Speed & Performance Exclusive Total Seal Ring Set: 4.010”+.005”, 1.5mm AP Stainless Top, 1.5 mm Napier 2nd, 3mm Oil Camshaft Bearing Set
Clevite LS1 H Rod Bearing and H Main Bearing Set for LS1 Stroker Applications
ARP Main Stud kit
GM LS1 Oil Restrictor, Oil Galley Core Plug, Large Coolant Plug, Small coolant plug
Assembled with PRC Double Valve Springs
Comp Cams Custom Order Camshaft: 232/240 .595/.609 115
TS&P 7.40 Chromemoly Pushrod
LS1 MLS Cylinder Head Gasket, 3.91 Bore, .040 Thickness
ARP 12 Pt. Head Stud Kit for LS2
Comp Cams OE-Replacement Hydraulic Roller Lifters,
GM LS1/LS2 Rear Main Seal Housing Gasket
GM LS1/LS2 Timing Cover Gasket, Valley Cover Gasket Oil Pump O-Ring
GM LS1/LS6 Balancer pulley Bolt Oil Pan Gasket
GM LSX Rear Main Seal, Front Crankshaft Seal
GM LS1 Water Pump Gasket
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
