Does this look ok. Cam question :)
Old May 31, 2010 | 03:02 AM
jasonpickett's Avatar
Default Does this look ok. Cam question :)
I have a:
lq4 6.0l
std bore
std stroke
h beam rods
diamond pistons 8.5 at 72cc
317 heads. Nothing done yet. Will put 2.08 and 1.60 in later with port and polish.
comp lsr .675 lift springs
comp rockers
I am running 96lb injectors
edelbrock xfi intake with 90mm tb
I am running a pt88 with a .96ar
Fast xfi
I was lookint at this cam:
http://www.compcams.com/Cam_Specs/Ca...csid=1425&sb=0
Do you think the cam looks good for my setup. Let me know if you need any other information.
Jason
Old May 31, 2010 | 03:07 AM
Oh yeah
3.5" turbo back exhaust
trans is a 4l80e with a 3500 stahl
gear ratio is 3:42 awd
