help with duel nozzzle meth
You are running 50/50 and it doesn't look like meth is a massive amount of your fueling so it won't throw things off too bad to step up a couple. Still would recommend rechecking on a wideband.
How are you making boost? If you are maxing out your hair dryer that could be the issue when you turn up the boost.
I think the recommended mixture is a good starting pioint and as mentioned should be used as a guide. I use -20 degree winddhield and then add a bottle of heet mixture seems good for me. The mixture can be debated forever many love 100% meth others 100% water both have their advantages mine is just flamable and seems a reasonable tradeoff for my setup
Good luck
