High compression with a turbo
Old Jun 4, 2010 | 01:03 PM
Phil99vette's Avatar
7 Second Club
Think of compression as a multiplier and boost as your base. The higher the multiplier the greater your compression is under high boost levels. The reason guys like to run low compression and high boost is it yeilds a lower effective compresion. Bottom line is the cylinder pressure it makes, you can make the same power with 2 different boost levels and 2 different compression ratios if it makes the same cylinder pressure. I like to run high compression for a couple reasons.... it makes spooling easier and you can make way more power when you throw the juice at it. For example....
8:1 and 30# of boost makes your effective compression 24:1
10.5:1 and 30# makes your effective compression 32:1
So your compression went up 2 points while your effective compression went up 8 points. But beware you better have an engine that can handle it. Our ECR is roughly around 40:1.
Old Jun 4, 2010 | 02:05 PM
ZL1Killa's Avatar
Holla back. LOL. I can tell you know engines pretty durn well. and very well stated, especially "But beware you better have an engine that can handle it."
Old Jun 4, 2010 | 02:10 PM
7 Second Club
LOL, we cant wait to try and run it out the back door again.... last year it went 199.86 on a pass where we pedaled it right at the 60' mark and put a cylinder out just before 1/8. Should go 210+ very easy.
Old Jun 4, 2010 | 11:29 PM
383lt1impala's Avatar
Originally Posted by chuntington101
That should spool pretty fast! lol What fuel are you planning on running and how much boost?
That's the idea im gonna run c16 and 6-10psi depending on what my engine builder likes.
Old Aug 30, 2012 | 02:10 PM
JoshuaGrooms83's Avatar
ok so with a really good tune and a stock 10.1 CR, whats a good safe psi level with a T76 rear mounted turbo? tryign to bring a good thread back alive.
Old Aug 30, 2012 | 03:51 PM
brians91formula's Avatar
Forged motor or stock? Head studs or head bolts?
Old Aug 30, 2012 | 04:01 PM
stock block but looking into arp head bolts or studs, leaning towards studs though. still on the fence with 317 heads.
Old Aug 31, 2012 | 08:04 AM
MaxxMitchell's Avatar
I have a few guys pushing 22-24lbs with 76mm's up front on 10:1. But all are on E85, LS9 gaskets, studs, stock heads, cams similar to the LS6.
Old Aug 31, 2012 | 08:56 AM
Grr's Avatar
Grr
I am putting together a rearmount setup with the 13:1 motor in my sig, on E85 of course not trying to make big power jsut 650whp or so. Probably only get away with 5-7psi before I start pushing water since the heads are so thin
Old Sep 16, 2012 | 09:20 PM
um, gonna stick to premium pump gas since E85 is hard to find lol
Old Oct 1, 2012 | 11:37 PM
tonybain42's Avatar
I've got a camaro with a 370ci, lq4 block, mahle forged pistons, compstar h-beams, dart 205 heads with ARP headbolts, fast 90/90 running about 11.3:1 CR I'm planning on adding a t70 rear mount turbo and was wondering what a safe boost level would be. The motor made 440 at the tire at EPS. and i'm running a T56 with a 9" rear and 4.11 gears, mainly street driven, but more power could never hurt, lol!
Old Oct 2, 2012 | 11:26 AM
  #32
ZL1Killa's Avatar
Stud it:
SEXY
on stock block....what about pistons and rods? stock also? if you are keeping 10:1 compression and running on 93 octane I see no reason why you couldn't run ~14~16 degrees maximum timing and run 12~14psi (to be in the 2bar sensor range). You will want to keep the fuel mixture in the 11s keeping her safe
Old Oct 4, 2012 | 03:24 PM
  #33
nice! i am actually. already on my "official" list of things to get lol
Old Sep 12, 2013 | 04:07 PM
  #34
heroz22's Avatar
Default 11.5:1
Ok fellas I know this is an old thread but this is what I want to do. The motor is 11.5:1 CR, I have JE custom nitrous pistons, stock rods with ARP rod botls, ARP main studs, ARP head studs, Thunder racing heads (Same as PRC stage 2.5) Thunder racing nitrous cam specs are close to 232/238, 42lb injectors, 255 pump and right now I am sendign a 150 shot to it and she loves it but I am wanting to go boost. I want to Build my own kit with a PTE 6262 on the rear and I was just curious if I could do this on pump. If not can I go E85 and make it work and work well. My power goal is right around 700. Please let me know what you guys think
Old Sep 12, 2013 | 08:24 PM
  #35
THADD's Avatar
Damn back from the dead. Ok so how about this, a guy I race with is running 12:1 comp with a 76mm around 25 lbs on c16. Yes it's fast
Old Sep 12, 2013 | 08:27 PM
  #36
smokeshow's Avatar
No, not on pump gas. Not with that turbo either. Or that cam. Or injectors or fuel pump. Everything would need to change.
Old Sep 23, 2013 | 08:50 AM
  #37
SuperC1's Avatar
For this I would run a bigger turbo and make it a front mount if possible, and then I wouldn't run any more than 8-12 psi with a good tune. I actually did this with a 76mm on 12psi and pump gas and it ran like a scald ape.
Old Sep 23, 2013 | 11:22 AM
  #38
gallo-lo's Avatar
Lq9 stock spec build using twin s366 BW e85 drinker..
Old Sep 23, 2013 | 11:41 AM
  #39
Black Reign's Avatar
Studed 408 at 9.7:1 with twins at 21 on e85 ftw!
Old Dec 1, 2014 | 07:18 PM
  #40
Michaelfir's Avatar
Im running a 12to1 compression BBC with tunnel ram in the picture i think i will show that on new guy,anyway i have a twin hybrid T3T4 turbos thinking about adding the turbo manifolds and tap into both carbs 1 for each with carb hat. I was told a high compression engine give u that good leave and the small 8lb turbos will spull faster than the large. the turbos have a built in blow offs and i have a couple of waiste gates, 1-5/8" headers shortfacing strait up i was going to wrap them for the heat. i running canfield heads big valves, 697 lft roller cam lifter all roller etc. any thoughts?
