vortech v9 boost question
Old Jun 10, 2010 | 12:10 AM
phatasp's Avatar
Huh I was told I could,nt do that. I like the idea of not having the hot air not going back through the motor.
Old Jun 10, 2010 | 11:27 AM
TX RED's Avatar
post some pics
Old Jun 10, 2010 | 12:35 PM
LSpeed1's Avatar
[QUOTE=transam151;13447490]
Originally Posted by LSpeed1
yes, it is that easy to vent to the atomosphere. Good picture of your set up LSpeed1 for example. I have an HKS as well, works pretty good. Im going to have to get some pics up soon to show you guys my front mount IC set-up
thank you. if im not mistaken, these babies are top notch bovs. instant pressure release.
Originally Posted by TX RED
post some pics
pictures of what?
Old Jun 10, 2010 | 12:59 PM
TX RED's Avatar
your setup..I just came home for lunch I can see all the pics now
Old Jun 10, 2010 | 01:00 PM
TX RED's Avatar
I see you change your oil feed line what size it
Old Jun 10, 2010 | 01:10 PM
DeltaT's Avatar
Having a blow-off valve on a MAF setup is not the right way to do it. The right way is a bypass valve like phatasp's first picture, though he appears to be SD.
The reason is that the MAF measures all the air going into the motor. If you dump some via the BOV after the MAF, the fueling profile for the motor, until the BOV closes and MAF-measured air catches up, will be off. You could have some ultra-rich spikes that risk washing the oil off your cylinder walls as a result. Rinsed cylinder walls lead to excessive ring wear which is never good with FI. Also leads to contaminated oil, another bad thing for FI.
SD setups can use a BOV no problem, but MAF can't.
Jim
Old Jun 10, 2010 | 01:31 PM
LSpeed1's Avatar
ill try and post up some more later when im off work.
im not too sure on the size, if i remember correctly, my previous one blew off during a dyno run. so i cant say exactly.
Jim
i was not aware of that, im going to have to look into it. i thought the only major difference between sd tune and maf was that with a maf setup you know the amout of air flow going into the motor, as where sd, your estimating the amount. am i incorrect?
and so what if i moved the maf after the bov and aftercooler, right before the tb?
Old Jun 10, 2010 | 07:04 PM
TX RED's Avatar
AnyBody swap there oil feed to a 4an line
Old Jun 10, 2010 | 10:43 PM
phatasp's Avatar
vortech has a stainless oil feed line on their website, but only for a 99 to 2004 gm truck. I wonder if it would work
Old Jun 11, 2010 | 12:12 AM
DeltaT's Avatar
That would work. As long as all the air measured by the MAF makes it to the motor you are OK. But if you are dumping air the MAF has already measured, then fueling is calculated for air that is no longer there, so you go rich. Think about this: You have a BOV and an upstream MAF. You are cruising along at 6000 rpm, then you shut the throttle. Blower is still spinning as the motor winds down, air is rushing through the MAF, getting measured then compressed then spewing right out the BOV but the injectors are getting fuel signals based on the air the MAF measured. The throttle is closed, but the injectors are squirting, rich condition and possible cylinder wall hose-down with gas.
Jim
Old Jun 12, 2010 | 12:54 PM
transam151's Avatar
Jim
Yea, I set up my MAF blow through style after the bypass valve which is vented to the atmosphere so I wouldn't run into this problem. This is pretty much the only way to do it if you plan to run a (bypass/bov) vented to the atmosphere.
Old Jun 14, 2010 | 02:34 PM
  #32
moddedta's Avatar
so did anyone find a place to get a 2.65" pulley yet? I've been pulling my hair out trying to find one
Old Jun 14, 2010 | 05:20 PM
  #33
2001WS6Vert's Avatar
I have Reichard racing 2.75" 8 rib pulley for $50 shipped if anyone is interested. It has grooves cut into it to help with belt slip. I know the shaft diameter is the same but I'm pretty sure it would have to be spaced out to be used with a G-trim (I had to cut it down for my YSi).
Old Jun 14, 2010 | 11:45 PM
  #34
phatasp's Avatar
transam151 said there,s one on ebay listed for a mustang but should work on ours.
