Im Back! Yea the guy with the Ebay turbo kit.
I have since installed sub frame connectors and a boost controller to the car. The addition of the speed inc alternator bracket and the powermaster 140amp alternator really screwed up my tune as everything is actually seeing full voltage now.
The original cables on the car were all shot with acid residue on the inner cable. I replaced it all with 0/2 Welder cable and now see 13+ volts. Before I was lucky to see 11.8.
Currently running the low boost at 6lbs and the high boost is set at 8lbs.
The boost controller is the Profec b 2. Its alright and gets the job done. I installed it in the little storage slot in front of the gear selector. Pics are available upon request.
Had the car thrown on a dyno for ***** and giggles and it made 401hp, 404 torque on a mustang dyno at 6lbs of boost. This is with the A/F really screwed up, as It is running really rich at under 10.0 because of the voltage increases.
There is alot of horsepower hiding and should come out with a good tune.
Actually thats exactly what its doing, then caused the plugs to foul.
I msged Frost to see if he can look at my tune but guessing he is busy. Anyone with experience wanna take a look at it and see if they can lean it out for me?
Once you get that fixed and get your afr right, you will see a world of difference.
Replaced the bad wires and wrapped the problem area in a little bit of aluminum foil then put them back into the spark plug boot/sleave for now. I was hoping the sparkplug sleeves would stop them from getting hot but its obviously not enough.
Going to purchase better sparkplug wire protectors to hopefully solve the issue.
Put the new tune on I got from Frost and the car feels way stronger. Happened to get pulled over right after my last run but the cop gave me a break.
Check out the pics.
From Number 3 and 5
