Survey says... 705rwhp!!!!!!!!!!!!!!!!!!!!!!!!!
simply awesome awesome awesome. cant wait to see the dyno graph. where did this combo peak?
also john, for years we have been talking about mn6 cars loosing 12-15% and autos (4L60e) loosing 18-20% but ofcourse it gets skewed at your power level. i believe teh th-400 would loose as much power if not more as the 4l60e - but this is speculative.
Congrats again John, glad to see everything is working out now..........
I can't wait to see that monster run at the track...........
I would say that the loss with a TH400 is no less than 20%
Scott, I think an intercooler swap will make a very big difference, based on that conversation we had a while back, I am running 5 more degrees of timing with the same gas. I really held back on bigtime pimping the Griffin stuff until I saw the numbers were going up and we were still running 23 degrees of timing.
Great numbers guy! So what cc dish are your pistons? How much compression drop do the 6.0L heads give you, say on a stock compression block? What is the cc of LS1 heads? What is the cc of LS6 heads?
Congrats!
Congrats!
Diamond pistons:
3.905 3.622 6.125 1.315 4314 .927x2.950 -8.6cc
6.0 heads have 70cc chambers stock, LS1 heads have 67cc chambers, I did the 6.0's mostly for the stage II porting and valvework more so than the compression drop since my 6.0's were cut to 69cci so the difference is only 2cc.
LS6 heads are 64cc's I believe. 6.0 heads are lower compression LS6 heads basically, and I did mine because they flow over 330/220 which I wanted. (Not the best 6.0 head flow numbers out there either these numbers are fairly average)
#33
Way to go John............... Hopefully us ATI guys can hit numbers like that when we get this Cog pulley stuff straightened out......
I would be very happy with numbers like that with my new setup.
Kyle
Kyle
#35
I'm sure you guys will figure out the cog setups. Who knows I might do one too someday.
Intmd8, can you email me the datalog so I can send it to Craig at FAST?
#38
The YS is rated at 1500 cfm and the Griffin intercooler was designed by Jim Burns over there to support that.
I would be curious to see what the YSi + C16 could do actually.
#40
Let me see if they can get us dyno graph today.
It was hard for them to get a solid torque reading since it's a non lockup converter, but it was around 625rwtq I think.
Doug I have heard 10% loss for T56 setups.
Smokin, I am going to remove the 4.11 gear and install a 3.70 or 3.50 gear. I will race on a 28x10.5 M/T ET Drag.
If I can venture a question... is RWHP on the dyno derived from the RWTQ value? I thought a dyno effectively measured torque, and HP was a computed value.
Anyway, great numbers... there's probably more in it.
