Flywheel holder necessary?
Old Jun 21, 2010 | 03:11 AM
XtremeDime's Avatar
Default Flywheel holder necessary?
Im swapping out my blown stock clutch for a Textralia oz700 and Im to the point where Im about to put the flywheel on. The how tos I see show them using a flywheel holder. Is this really necessary? I mean cant I just get a couple bolts in there well and do a criss-cross pattern to tighten evenly?
Old Jun 21, 2010 | 08:18 AM
ryarbrough's Avatar
Shove a screwdriver through a hole in the flywheel and jam it against the block to keep it from rotating.
Old Jun 21, 2010 | 08:55 AM
Tally TransAm's Avatar
Just put a wrench on the crank bolt and hold it there
Old Jun 21, 2010 | 09:06 AM
cjmatt's Avatar
yeah, ive always just used the jame something thru trick. A long screwdriver jammed in on the drivers side of the block works fine
Old Jun 21, 2010 | 09:25 AM
AFASTYZFR1's Avatar
Just put a wrench on crank bolt to keep motor from turning or use an impact if you dare. But the screwdriver sounds like a good idea too, never done it though.
Old Jun 21, 2010 | 11:21 AM
Ryan33187's Avatar
+1 for hold the crank bolt
Old Jun 21, 2010 | 12:30 PM
HydroStream6's Avatar
I've always just grabbed the teeth of the flywheel with a rag and held it while a buddy tightens the bolts.
Old Jun 21, 2010 | 12:54 PM
mwg2600's Avatar
Ive always jammed it with a pry bar. I have always wanted to get the little tool that goes where the starter bolts on.
Old Jun 21, 2010 | 03:10 PM
XtremeDime's Avatar
Ahhh thats all it is? Well **** I could have done this last night.
Old Jun 21, 2010 | 03:28 PM
lowerthanyou00's Avatar
Harbor freight sells flywheel turners cheap, I personally use a snap on one since I'm always knees deep in automatics. Same indea for a flywheel tho ud just hold it in place instead of turning it.
