90mm LSX+Supercharger
Say you have 8lbs of boost with a LS6 intake and make 420hp.Switch that to a bigger intake like the LSX and the boost pressure should drop to 5-6lbs but hp should go up to like 440 or so..It's like more HP with less stress.
will the LSx clear the vortech discharge tube?
I understand that it is taller than the ls6.
I have not installed my vortech yet, so i don't know how close it is to hitting top of intake.
Thanks
Ryan
Ryan.
less stress???? How about the stress of $1363 out of your pocketbook. Im with ya on the less boost more power bit. I think they need to test it on FI setup so we can all see what it does so then some of us will believe in it a little more. Thats just my .02 though
well yeah.....though the pulley and the intake will always outperform the pulley
Go to a smaller pulley and you will make more power to a point. Beyond a certain point you will not be able to overcome the density loss due to heat. Also, higher charge air temps promote pre-ignition and detonation. What if you are already at the point where you can no longer "pulley up" for reliable power?
J
Put LSx intake and 90mm throttle body.
Does that mean 2psi of boost 520rwhp?
Then can I get a smaller pulley to bring me up to up to 4 psi again.
So that means more rwhp right. 2 psi worth so lets a say 26rwhp per one pound of boost (well for me at least).
Not sure I make sense but you guys can figure it out
.Oh ya I will be doing my bottom end but if I can hold off for a while
that would be great.
You can't just boost a motor to infinity.
If I took my current setup, and put a sheetmetal intake on it, and a bigger TB, I would be able to boost it more and make more total power.
I think the LSX 90mm plus the 90mm TB might help total output for a car like mine.
Please chime in so I can understand this situation better. I have a D1SC on my 98 SS and am considering an LS6 intake among other possible mods!
