IROC Boost
Old Aug 6, 2013 | 06:11 PM
  #141
grifter757's Avatar
Haven't updated this in awhile, well because I haven't had anything to update. Well got 95% of everything to get it moving again and should have it at the Holley LSFest.
Old Aug 6, 2013 | 09:12 PM
  #142
shawnc16's Avatar
Your wastegate is mounted wrong. Besides that, looks badass!
Old Aug 7, 2013 | 08:01 AM
  #143
grifter757's Avatar
Yea just threw it on there. Whoops.
Old Aug 10, 2013 | 03:44 PM
  #144
reaper68's Avatar
Question about the Holley Hi ram, did it take any mods to fit it in there? Also how tall of cowl are you running, could you run a piece of masking tape across so we can see how far it is above the fender?
Old Aug 12, 2013 | 10:53 AM
  #145
grifter757's Avatar
I'm running a SS hood... So it might need some cutting. I'll try and get a pic of what you want.
Old Aug 15, 2013 | 07:21 AM
  #146
grifter757's Avatar
Getting there. Hotside mounted, my 6 core intercooler is in and cold side either in or mocked up ready to get tigged up. 408 motor with TFS heads will be finished this weekend so will be swapping out motors. Soon... SOON....
Old Aug 15, 2013 | 08:31 PM
  #147
fastsspr's Avatar
I going to be in the Holley LS fest hope to see you there. If a Puertorican guy talk with you going to be me. Love your car. My first car back in a days was 1985 Blue Iroc .
Hope you ended the project by Holley Fest!!
Old Aug 29, 2013 | 06:11 AM
  #148
grifter757's Avatar
My SS Hood was stolen out of my front yard last weekend... Still pretty pissed about this so if you see a thirdgen with a Blue and black SS hood and then the underside of it has what looks like a fat "T" shape cut out of it. Please let me know.
On a plus side new 408 motor is in, Specs are:
Arias Pistons, No dish this time
Billet Rods
Billet Crank
Custom Spec Cam From Ed Hutchings
Link Bar Lifters
TFS 235 heads with a "little" work done to them
Harland Sharp Rockers
then of course topped off with the Holley Hi-Rise and a NW 102 TB.
Also decided to sump the tank and run a Holley Dominator External Pump.
Getting close to the deadline but I'm confident it'll run for LS-Fest.
"We could push it across the finish line... or tow it..."
Old Aug 29, 2013 | 11:22 AM
  #149
shawnc16's Avatar
Lookin good! That is a massive intercooler! Shitty deal with the hood.
Old Sep 3, 2013 | 07:53 AM
  #150
grifter757's Avatar
Talk about down to the wire... Holley Dominator pump and all Lines ran to the fuel rails, then back to the regualtor then returned to the tank.
Wiring harness is in. Got a few more wires to hook up or extend.
Turbo Cold side is almost done. Few more odds and ends and hopefully fire it up today or first thing tomorrow.
Old Sep 3, 2013 | 12:26 PM
  #151
shawnc16's Avatar
Good luck! Need vids when it starts!
Old Sep 13, 2013 | 11:09 AM
  #152
grifter757's Avatar
Although did not finish the car in time we still took it to LSFest. Ran into a couple little issues at the last minute and instead of rushing it just took it as is. Got the last few things coming so it should be running in a week and get some shake down in so we can actually make good passes at the Shootout.
Spent most of my time at the fest working on this.
Old Sep 16, 2013 | 01:56 PM
  #153
Turnin20s's Avatar
Iroc is looking great, I can't wait to see it all put together
Old Sep 16, 2013 | 03:17 PM
  #154
blue89irocz's Avatar
Subscribing. Looking at doing a similar build.
Old Oct 15, 2013 | 09:24 AM
  #155
grifter757's Avatar
Rad lines done, Fluids in, Just a few electrical things to finish and then it shall run...
Old Nov 13, 2013 | 08:20 AM
  #156
grifter757's Avatar
So was all ready to start the IROC FINALLY and... nothing. Would crank all day but nothing. After lots of troubleshooting found it had no fuel pulse or spark. Pulled the wiring harness I have back out of the car and the Crank sensor wiring has been sliced like 8 times so hopefully thats all it is. Will try again today. Keep your fingers crossed for me!
Old Nov 13, 2013 | 02:46 PM
  #157
shawnc16's Avatar
Hell yes! Need video!
Old Nov 13, 2013 | 08:04 PM
  #158
wicked z28's Avatar
Sikk *** iroc
Old Nov 13, 2013 | 08:49 PM
  #159
gnx7's Avatar
I skimmed thru the entire build. Crazy to see all the turbo setups, intake changes, Kmember changes etc. Talk about car ADD
Finally it is going to be a real beast.
Old Nov 14, 2013 | 08:06 AM
  #160
grifter757's Avatar
I do have really bad ADD But most of the changes where as the car got more and more extreme. In the end I just wanted to be able to jump in the car whenever I wanted and cruise around in it then go to the track and flog it and not have the "is this going to hold the power, or I should of done this whats there is kinda sketchy". I know there is always the unknown but in the end I built the car to handle what the pottential max output of the turbo setup is... We shall see though.
