turbo spark pulug and gap
Try to find best spark plug for my new project lq4 block 317 heads target 15 lbs on FI and looks like most of the people here are using Ngk tr6 at gap 30-35. I am concerned because of the difference in heat range.
Before I use them and since most of the search found is old I would like to have new opinions on best recommended spark plug and gap for my new application
Thanks
Tony
Thanks
Tony
Thanks
Tony
I've been running that same plug for years. My old setup was an LS2 402 with about a 380 shot of nitrous. I ran them with a .029 spark back then but on boost I had to tighten it up as I too was blowing it out. Even still, I ran the car alot NA and it ran 10.3's. I tried switching to a TR6 and alittle more gap and picked up nothing at the track one night. I swapped them back the same night.
Be sure you have the tune close before you start switching the plugs out. Check for adv and disadv of each one like knock, hp/tq #s, driveability, color and any other misc things a good tuner would check for.
This is just an idea and I'm by no means an expert on this but only seems a good way to make a right choice on the plugs.
In your experience how were were they blistered? I havent pulled any of the plugs yet but would like to know what to look for. Thanks
What's the difference between the BREF'7's and the 5671A-7? I use the 5671A-7 or 8
