How much boost before intercooler is needed
Old Jul 8, 2010 | 05:40 PM
98Z28CobraKiller's Avatar
Restricted User
Nice illustration Bob.
Old Jul 8, 2010 | 05:53 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by XtremeDime
How much pressure drop would you get from running 2 ICs though?
There isn't much of a restriction, it is a pretty efficient set-up. We had a 347 cubic inch engine with a D-1SC at 16 psi of boost in a Corvette C5 with this set-up. The car was used on a road course and the set-up worked quite well, as it did not block the radiator. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jul 8, 2010 | 06:00 PM
LS1Tech Sponsor
Thanks, this link will show you much more. http://www.ls1.com/ed/procharger_owners_manual.pdf Bob
__________________
Old Jul 8, 2010 | 11:11 PM
09camaro383's Avatar
Originally Posted by cbr600rx7
10 psi is pushing on a LSX by a lot but it depends on what compression you are running. Even with meth/water thats on the high side of what most people would call safe. Somthing to keep in mind is its not all about "PSI" for example a GSX eclipse with the factory turbo running 18-19 psi may make 200 whp. A T76 on a LS1 at 9 pounds will gain about 200 whp from its factory 300ish. Pounds of Boost is not the key when making power on a FI set up but more about matching the right compressor size to the right set up since a larger compressor will flow more air at lower boost over a smaller one. Just my 2 cents.
What do you think on this set up? This is what i have ls3 with a 418 stroker kit 823 heads i think they are 68cc, Wiseco Forged Piston -20cc Dish and a custom cam 236/236, .602"/.602" 115 LSA
Old Jul 8, 2010 | 11:32 PM
Bob@BruteSpeed thanks for the illustration nice!!! Thats what I been looking for!! were can i get those parts?
Old Jul 9, 2010 | 03:48 PM
anyone? should i call procharger?
Old Jul 9, 2010 | 03:59 PM
LS1Tech Sponsor
You're welcome. New from ProCharger will be in the $1400.00 range. Guys will sometimes swap them out for a front mount when they start boosting past 14 psi, and a lot of times you can buy the complete assembly for $400 to $500 used. I see them on here is the used section every now and then. Bob
__________________
Old Jul 9, 2010 | 04:08 PM
elias_799's Avatar
how much methanol are you willing to spray ?
Old Jul 9, 2010 | 07:43 PM
kikass_z28's Avatar
'trust' ran twin coolers and a d1sc with a 396 making 808rwhp. I dont think they will hold you back. Not many people have reached numbers this high and it was through a stalled auto. just my .02
Old Jul 9, 2010 | 10:44 PM
the kit came with the methanol stuff but im trying to stay away from that!! Im planing on using 91 octane that is the highest I can get in Arizona!! do i have to use methanol to run 8 or maybe 10lbs?
Old Jul 9, 2010 | 11:54 PM
XtremeDime's Avatar
Depends on your IATs. I would get some logs done and see what your temps are doing before you say no to meth.
Old Jul 10, 2010 | 02:55 AM
  #32
cbr600rx7's Avatar
Why dont you want to use meth?
Old Jul 10, 2010 | 03:24 PM
  #33
elias_799's Avatar
what CR is you motor ?
if you do not want to spray meth or run an intercooler and you actually drive the car i would stay away from FI
Old Jul 10, 2010 | 05:38 PM
  #34
my C.R will be around 9.8:1 and i will be using an intercooler but i want to stay away from meth
Old Jul 12, 2010 | 05:19 PM
  #35
if possible none!!
Old Mar 14, 2011 | 12:05 PM
  #36
Vetal's Avatar
Guys where do you get meth? Is it so easily obtainable?
Old Mar 14, 2011 | 11:20 PM
  #37
overhere's Avatar
windshield washer fluid.
Old Mar 15, 2011 | 02:29 AM
  #38
Vetal's Avatar
:O you put washer fluid into the engine???
Old Mar 15, 2011 | 03:55 AM
  #39
LS1Tech Sponsor
Local dragstrips usually sell 100% methanol and it is normally a lot less money as they get it in 55 gal barrels. For forced induction I recommend using 100% methanol, as a water mixture tends to put the flame out. Bob
__________________
Old Mar 15, 2011 | 04:02 AM
  #40
Vetal's Avatar
Lol, my local dragstrips sell hotdogs and cola at most )
