how much boost with Ttrim
Old Jul 10, 2010 | 12:50 PM
phatasp's Avatar
Default how much boost with Ttrim
Any vortech guys give me an idea how much boost I would be running with a 275 pulley? I,ve got dart heads,fast intake and throttlebody, long tubes and a small cam. Stock cubes. Thanks
Old Jul 11, 2010 | 11:56 PM
phatasp's Avatar
Ballpark? vortech guys?
Old Jul 12, 2010 | 11:16 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
18 psi?
Old Jul 12, 2010 | 05:30 PM
phatasp's Avatar
I guess I better be looking for a new pulley. Any idea what size I would need for 10 or 11?
Old Jul 12, 2010 | 11:01 PM
DeltaT's Avatar
For stock cubes I would do the 2.95 if you spin it to ~6500 or the 3.12 if you spin it to ~7000. Ballpark stuff.
Jim
Old Jul 13, 2010 | 08:21 AM
LS1Tech Co-Founder
I had a 2.75 pulley with my now very old YSI setup and I saw 21.5 psi with stock cubes.
T-Trim is rated for 900 hp I think, I have forgotten but it's on Vortech's website.
The stock G-Trim kit runs a 3.12 pulley with the aftercooler so I'd probably stay around there to baseline or try a 2.95. If you look around you can find Vortech parts.
Brian aka Sunset01TA or something like that has a T-Trim but it's a built combo maybe he'll see the thread and chime in.
Old Jul 13, 2010 | 01:12 PM
phatasp's Avatar
Thanks you guys, I was thinking 2.95 it,s just hard to tell going from g to t trim. I,ve still got the stock bottom end and don,t want to end the summer early.
Old Jul 13, 2010 | 02:01 PM
LS1Tech Co-Founder
So you were running a 3.12 then if you have an aftercooler? Those make 10-12 psi? I'd look for that 2.95 or 2.85, but I wouldn't mess with a 2.75 unless you plan to run race gas.
Old Jul 14, 2010 | 04:45 PM
phatasp's Avatar
I was running a 2.75 and only getting about 7lbs on the gtrim so I was hoping a 2.95 would put me at around 10 with the t trim
Old Jul 15, 2010 | 09:41 AM
LS1Tech Co-Founder
7 psi with the G-Trim, that sounds low no?
When I was buying pulleys, they weren't too pricey.
Old Jul 15, 2010 | 10:49 AM
phatasp's Avatar
I though it was low. I changed to a 2.50 reichart racing pulley and was getting 9, I thought it might because of the intake and heads. I don,t think the belt was slipping at leastit did,nt look like a lot of belt dust.
Old Jul 17, 2010 | 08:06 PM
NAVY's Avatar
2.75 with 402 c.i.d , z06 2002 intake , vortech t.trim 15 psi 760 rwhp
Old Jul 18, 2010 | 11:24 PM
phatasp's Avatar
THATTA WORK! I would be happy to see 600 with what I have,a 2.95 pulley and a good cam
Old Jul 19, 2010 | 11:07 AM
ss1's Avatar
ss1
My new setup will use the same blower, pulley size, engine size, but I was guessing it will see 10-12-14lbs of boost. Of course there are many other variables that determine the exact boost# you will see. Fwiw, my G-Trim with a 2.65" pulley makes just over 7lbs.
Old Aug 23, 2010 | 11:44 PM
TransAmatt99's Avatar
If anyone is interested my setup makes 12 with the airlid on and 14 with the lid off.
