on a d-1sc kit will the intercoolers flow...
But we will see..........
Thats where the front mount griffin intercooler comes into play............
Just my opinion though.
ie: A 1400 CFM intercooler should flow 1400 CFM with ~2 psi pressure drop across the core.
If the DP across your intercooler is greater than 2 psi, then you have maxed it out. Not only does this cut the amount of boost that you will see at the manifold, but it will also push your air intake temperatures up. The undersized intercooler acts as a greater restriction to the blower than necessary and as a result, blower discharge pressures are higher (even though the manifold ie 'boost' pressures are lower). The higher the blower discharge pressure the greater the intake charge temperature.
So, an undersized intercooler is a double-whammy. You get higher intake temperatures than desired and lower boost pressures (at the manifold).
Properly sizing the intercooler is key. If you don't properly size your intercooler you may be better off without it.
-Kevin
