sts rear mount turbo. yes or no?
I have a cammed and full bolt on m6 2000 trans am. i'm thinking of throwing on an sts rear mount as well. this is one kit that i found below. What else would i need to buy with it besides gauges? Is it worth it? Will this end up killing my motor? Is there some where i could buy it cheaper as well? Thanks guys.
as long as your motor is healthy a turbo is a great way to go. Turbocharging is expensive however, and with the capabilities of so much more power you have to consider is your tranny up to the task. But if you dont get too crazy you will be very satisfied with the kit.
Heres the #1 thing you need to know about going to forced induction....Without a good tuner to get it right for you...your motor will be a boat anchor real soon. Spend plenty of money and time ont he tune.
Also your gonna need all the fuel system upgrade, pump, injectors, etc. Like i said its not cheap but the end result is typically awesome and can double or triple your HP depending on how radical you go.
