breaking up around 5k HELP PLEASE
well I've noticed that it keeps blowing my bypass valve hose out. what does that mean? I would think it's not closing under boost and the amount of air the blower is forcing through it is causing it to be pushed out.
I also have the stock pump with an inline 162lph pump suplied by procharger with 50# injectors, Are my pumps able to keep up?
HELP PLEASE
HELP PLEASE
i had the same issue, ended up going through 2 sets of plugs/wires before it was fixed. replace your wires/plugs even though the look good, i never found the culprit, but fixed the problem
