i have turbo questions......
Old Jul 20, 2010 | 08:13 AM
krislem1990's Avatar
Question i have turbo questions......
ok i been having my SS for about a year. and i jus ordered a 76mm turbonetics turbo for it. 4 inch inlet and 2.5 inch outlet. i can get more specs if needed. i jus want to know if anyone can tell me EXACTLY everything i need to put it on the car. the car is completely stock other then exhaust. please let me know what i am up against
Old Jul 20, 2010 | 09:04 AM
OUTLAWZ RACING's Avatar
sticky^^^^^
Old Jul 20, 2010 | 10:12 PM
i jus want to know what i am up against. jus trying to get numbers and prices together and ordering the things i need
Old Jul 21, 2010 | 08:43 AM
LS1Silverado05's Avatar
Might as well start with a fuel system....
Old Jul 21, 2010 | 08:53 AM
ZGOBYBY's Avatar
I would say start out with an intank Walbro 255 pump, and some 42 LB injectors for the fuel system. That is a basic setup you could go with. Tuning is critical, you don't want to flood the motor out by not flashing the PCM for the injectors.
I would also say do some suspension upgrades; I know it's not turbo-related, but I found that suspension made a huge difference. Get some LCAs, some relocation brackets, SFC, and a torque arm so you can atleast put some of the power down.
Also, you have to think about what BOV and wastegate you are going to purchase? Are you going to go with an electronic boost control system, or a manual one? Also, intercooler. You have to consider how you are going to mount that, etc. There is so much to it.
Old Jul 21, 2010 | 09:40 AM
well i am still getting things together that i need. i know i am getting a JGS 44mm waste gate tial 40mm BOV i am gonna front mount it behind the radiator. i already have alot bought for the car. i am in iraq rite now so i am in the stage of buying all the things i need to get started on the turbo system when i get back. the car is goin to the shop to get painted and its getting some things that i bought, like eibach lowering suspension, stage 3 clutch, short throw shifter, new shock tower brace made by 6litereater. a few cosmetics like new MOMO steering wheel, and some other interior stuff, i am thinkin about changing the heads on it after i get back also. i was thinkin about some 317 heads. i pretty much have the idea of how the hot side will be made for the turbo i jus need ideas on the cold side. like where to mount the filter, i ama newbie to boost so i will have questions here and there
Old Jul 21, 2010 | 10:54 AM
transammiller's Avatar
Restricted User
i disagree about your statement about the fuel system. do it once and do it right. you should do at least a -8 Feed and -6 returb or use the stock feed as a return, twin intank Walbros, fuel rails, boost referenced fuel pressure regulator, and pressure switch to engergize the 2nd pump. I would recommend 60s at the minimum for injectors. the tune will be the most important part and a good tuner can get you sorted out.
Old Jul 21, 2010 | 12:35 PM
damn man yalla re speaking greek to me i have no idea wat i am gettin myself into. i jus need to take it slow at first and get all my sources together. i am really thinkin about sendin it off to a shop to get it all done haha
Old Jul 21, 2010 | 12:38 PM
dimetweaker's Avatar
that might be the best idea if the above posts make no sense and youre in a hurry to get it done. These arent exactly a bolt on!
Old Jul 21, 2010 | 01:11 PM
well i am not in a hurry to get it done. i jus want to know wat i am up against with this
Old Jul 21, 2010 | 01:24 PM
XtremeDime's Avatar
Its cool man, last fall when I started my build I didnt even know how a turbo worked. Youre going to need 2 walbro fuel pumps and 60lb injectors at minimum, you dont need to worry about the larger return and feed lines unless youre looking for 600+
Keep reading while youre in the desert and youll have a good idea what youre doing by the time youre back. Thanks for serving!
Old Jul 21, 2010 | 01:40 PM
TurboS10's Avatar
As posted earlier, see the sticky. It's all there.
Then come back with questions on what you can't figure out.
Also, these don't go together quick. Unless you want to spend your off time building it. You really should consider getting it built.
Old Jul 21, 2010 | 02:42 PM
thanks fellas. i am glad that yall are answering my questions. i am jus trying to get the scoop on how hard it woult be and wat all do i need to get it rite not to half *** it. and 600 would be way to much hp for me. well atleast for now. i am looking at the 450-500 hp range.
Old Jul 21, 2010 | 02:46 PM
450-500?... On your worst day you can reach those goals with a turbo car. Mark my words... you will turn it up....
Old Jul 21, 2010 | 03:54 PM
but remember it is a stock motor. i dont want to blow anything in the bottom end jus yet. lol. i wanna beable to get used to boost then when i get ready i might put aside a motor and maybe start a forged 383 or something. maybe a LSX. but i wanna learn boost firts before i get into building a new motor and see wats the capabilities of this turbo cause it is said to be safe to push 9psi of boost on a stock motor and not have to worry? is that true?
Old Jul 21, 2010 | 04:31 PM
98Z28CobraKiller's Avatar
Restricted User
At this point in your education process, you should read all the stickies at the top of the Forced Induction section. Then read other people's build threads. Ask specific questions to the people in their build threads. Anyone that has a build thread going (usually no matter how old) will have notification that you have posted in their thread and will respond quickly. General questions tend to get overlooked as they require very lengthy answers. This is the very best way to see what you are getting into as you will see all the snags that people have run into along the way. Here is a link to my first build. I tried to be very thorough and include as many details and pictures as possible. Your fuel system requirements will be less and you are using a smaller turbo, otherwise it's pretty much the same thing.
https://ls1tech.com/forums/forced-in...ld-w-pics.html
Old Jul 22, 2010 | 01:14 AM
well i am pretty sure i can get some of yall on here to let me know wat i need to know. i am pretty sure i can pick up the hot side off of here. someone already offered to build me one but the price that he gave me was rediculously high. so i am trying not to get stiffed with overpaying for something. i am pretty sure that the truck manifold kit which consist of the whole hot side for like 900 dollars is a little high? i am prolly gonna start on the build next summer cause that way i can have it down for the summer so that way if i take the AC out it will start getting cooler when i get it all together and running. i am very grateful to all of you replying to my thread and thanks for the info. pleaseee keep it goin with the info
Old Jul 22, 2010 | 02:22 AM
BottleFedZ346's Avatar
I payed about $800 for my complete hotside stuff including truck manifolds/mild steel crossover and downpipe.....
If your looking for hotside stuff for sale look in the classifieds section and search for turbo and you will find a couple of people selling truck manifolds and hotside parts.....
Old Jul 22, 2010 | 04:45 AM
ahh ok. well i looked around but i really dont know if i am gonna be buying the rite thing. i been reading forums and learning how to do it and the things i need also
