Crossover / hot side sizing
Old Jul 21, 2010 | 09:57 PM
Ping King's Avatar
Default Crossover / hot side sizing
Hey Gang,
I am trying to plan my setup. This is what I have so far:
Precision 67mm turbo
2 stainless 98 passenger manifolds
3" downpipe
2 deltagates.
I am contemplating what size i should make the crossover.
do you think 2 inch pipe would be ok?
Max power is 550 rwhp. No more. There would be a wastegate directly off of each manifold, then 2 inch to the turbo. I am looking for a setup with instant response and spool.
Opinions?
Old Jul 21, 2010 | 10:02 PM
trans2000am's Avatar
2.5 is good, turbo is a little small for the ls base motors your gonna run out of steam real quick
Old Jul 21, 2010 | 10:06 PM
Ping King's Avatar
i know ill be limited to 9-10 psi. So i am building this setup with that in mind.
Old Jul 21, 2010 | 11:32 PM
BottleFedZ346's Avatar
Im runing a 2.5 mild steel setup.....
Old Jul 21, 2010 | 11:48 PM
1972nova's Avatar
im going 2.5 on my 5.3 t70 setup
Old Jul 22, 2010 | 10:54 PM
From what i have seen 2.5 is most common and wouldnt think you would need much bigger then 3.....
Old Jul 23, 2010 | 03:25 AM
DMH Fabrication's Avatar
If you never plan on going bigger later, I think you could get away with a 2.250" crossover. I feel 2" is a little too small though.
