Need fast help! F1a won't fit!!!
All-
I'm trying to get my build wrapped up and can't seem to get my F1A to fit right. I mocked it all up on the motor while it was on the K-member outside the car. Once the motor started to go in (from the bottom) I realized it wouldn't fit right off hand. I removed it, got the motor in, and now I can't get it to fit in there! I've tried from the top and from the bottom. I'm crammed between the water pump and the ABS block, and the radiator is giving me a bit of hell in the front (but with the radiator support removed, I got a bit of play room.
Car is a 97 Z28 with ABS/TCS, stock fans on radiator. Any suggestions?
