High boost low compression guys.. answer this survey
I know there is no magic #s, but I was hoping that this might reveal some general trends.
CI:
Chamber volume(cc's):
Piston dish(cc's):
Static compression:
FI method/compressor size:
Max psi:
Redline:
A/F at peak TQ:
Timing at peak TQ:
A/F at redline:
Timing at redline:
Injector size used:
Fuel used:
Max HP: @x rpm @x psi
Max TQ: @x rpm @x psi
Chamber volume(cc's): 69cc
Piston dish(cc's): -8.6cc
Static compression: 9.1:1
FI method/compressor size: Vortech YS Trim
Max psi: 17psi on my car, but the unit will do 27psi
Redline: 7200
A/F at peak TQ:
Timing at peak TQ:
A/F at redline: 11:1
Timing at redline: 23
Injector size used: 83 Siemens, base fuel pressure is 43psi
Fuel used: VP C12 + 93 octane (approx 5 gal C12, 3 gallons 93)
Max HP: 719.5@6700 rpm @17 psi
Max TQ: 700 @ x rpm (hard to measure without locking the converter but it was 700)
