How well do 383s do under boost?
Old Jul 29, 2010 | 04:51 PM
IWGF's Avatar
Default How well do 383s do under boost?
Good? Bad? Reasons?
And if any of you guys are running a boosted 383, what are the specs on your motor and FI setup?
Reason I'm asking is because I'm planning on doing a 347 w/ a 76mm Truck Mani kit and one of my friends asked 'why don't you just do a 383?' so now I'm asking because I don't know why you wouldn't do a 383 right?
Thanks guys
Old Jul 29, 2010 | 04:59 PM
RCC's Avatar
RCC
Thats a really open question. As its really the parts and assembly of a motor that makes it boost friendly rather than the cubic inch. But to answer your question about 383ci motors and boost, LMR finished this rear mount C5 with a 383 recently and this car makes stupid power, the car made 1200rwhp with a single GT47-88.
Heres the thread about it
https://ls1tech.com/forums/texas-mem...-1200rwhp.html
Old Jul 29, 2010 | 05:01 PM
MIGHTYMOUSE's Avatar
383 would require you buying a crank.
considering you would be on 4 bolt heads i dont think it would be getting you much more than being able to say its a 383.
also raising cubes does not raise how much hp a turbo can make...tq yes.
Old Jul 29, 2010 | 05:42 PM
IWGF's Avatar
I know I'd have to buy a crank.
So the difference between a 347 and a 383 is fairly minor when we're talking FI then?
My original plan was for a 347 w/ about 9.5:1 and a small custom grind boost cam w/ a Precision 76mm on a truck manifold style kit.
Sounds pretty solid I think. Opinions?
Old Jul 29, 2010 | 05:44 PM
castine917's Avatar
a fellow in a local club was running a 383 in his 69Z @8.99. still street driven too. good luck finding any online info on his car though. can find him on ------------------------- tell him chad castine said to ask. he might be willing to share some info then or maybe he will just beat me up.
Attached Thumbnails How well do 383s do under boost?-tim_rood.jpg   How well do 383s do under boost?-rood_6.jpg
Old Jul 29, 2010 | 10:43 PM
TurboS10's Avatar
I'm doing the iron 347 with ported dart heads and a mid 220 cam w/ twin 61mm.
Old Jul 30, 2010 | 02:20 AM
venom ws7's Avatar
IMO if you went with 383 then go with bigger turbo....
And yes if the 383 was built right it will handle a lot of boost like RCC already posted.
If I had to choose I'd keep the 347 or go 400+ci.
I'm planning to keep my 347ci 8:5 compression (I'm rising the boost a little though 8:8)
and going with something between 80-85mm turbo (depends on what I can fit on the damn Vette)
Old Aug 1, 2010 | 09:44 AM
castine917's Avatar
Originally Posted by castine917
a fellow in a local club was running a 383 in his 69Z @8.99. still street driven too. good luck finding any online info on his car though. can find him on -----------------------------. tell him chad castine said to ask. he might be willing to share some info then or maybe he will just beat me up.
ran into his car yesterday and i feel bad now. his is standard bore for 377 cubes. your also looking ls while he has early gen dart.
Old Aug 1, 2010 | 09:47 AM
Z06PSI's Avatar
383 here with an Eagle crank and Callies rods.
