what the best spark plug ? 18 psi
Old Aug 3, 2010 | 10:29 AM
LS1RedZ's Avatar
Where can you get the TR7s? I looked for them and nobody had them anywhere.
Old Aug 3, 2010 | 02:37 PM
98Z28CobraKiller's Avatar
Restricted User
As long as you aren't rich at idle, it's fine.
Old Aug 3, 2010 | 03:04 PM
KILLER-LS1's Avatar
Read this on heat ranges: http://www.ngksparkplugs.com/tech_su...2.asp?mode=nml
Old Aug 3, 2010 | 03:07 PM
KILLER-LS1's Avatar
http://www.youtube.com/watch?v=LbR75...layer_embedded
Old Aug 3, 2010 | 05:03 PM
HydroStream6's Avatar
TR7s technically don't exist. Look for 3346 or BR7EF NGK
Old Oct 21, 2010 | 08:06 AM
turbo370supra's Avatar
some smart turbo guys in here.
1100 ish to the flywheel. im using gas with meth injection. 19-22 psi. go with 7s? or 8s?
Old Oct 21, 2010 | 10:20 AM
Phil99vette's Avatar
7 Second Club
These are very nice plugs at your power level.
http://sparkplugs.com/more_info.asp?AAIA=&pid=7908
Old Oct 21, 2010 | 04:24 PM
Restricted User
Also, make sure to get the correct plug for your specific head. Some heads require a gasketed plug while others just have a tappered seat. My AFR heads use a tappered plug. We just found out that the TFS heads should be running a gasketed plug but have been running a tappered plug in them all this time. DOH.
Old Oct 21, 2010 | 05:20 PM
tomz28's Avatar
well thats good to know im about to change my plugs out. let me know what the part numbers are ill be looking for some in the 7 range thanks
Old Oct 21, 2010 | 08:56 PM
i have trickflow cnc 225s. so phill will thoes 3911's go right in? tamperd seat or gasketed?
Old Oct 21, 2010 | 09:05 PM
7 Second Club
The part number I listed will work fine in that application. We had good luck with the AR3911s before we started turning the boost up. They ran fine in our 7.6 second passes years ago. Since then we have changed plugs but for a 8.0 to 9.5:1 and under 25# of boost they should work well.
Old Oct 21, 2010 | 09:13 PM
  #32
the 3911s compare to what on the ngk scale?
Old Oct 28, 2010 | 10:29 AM
  #33
stangeater01's Avatar
what gap are you running on the 3911s s85 370cid in the neighborhood of 1k hp
Old Oct 28, 2010 | 02:57 PM
  #34
Johnv's Avatar
TR8s here @ 25 thou gap
Old Oct 29, 2010 | 08:56 AM
  #35
7 Second Club
start at 22-24 thou
Old Feb 21, 2011 | 07:37 PM
  #36
Swerve7rpm2000's Avatar
Hey Phil can i get your opinion on some spark plugs.... i have a set of 225 tfs heads 408 pt88 prolly run a max of 15 psi to start off with, AR3911s? and what kinda gap .25 to be safe? thanks
Old Feb 21, 2011 | 09:21 PM
  #37
AFASTYZFR1's Avatar
I run BR7EF
Old Feb 22, 2011 | 12:10 AM
  #38
cracker's Avatar
Are you guys on crack? What is the part number for a TR7 ore a TR8??
Just curious.
The only TR part number worth talking about is a TR6. And as stated before, stock motor, decent shot plugs. If you want to go colder, go with BR7EF. THESE ARE NOT TR7's
tr7's and tr8's do not exist, except in the iridium line. I don't know if they even make those anymore.
Old Feb 22, 2011 | 12:11 AM
  #39
cracker's Avatar
Originally Posted by AFASTYZFR1
I run BR7EF
Thank the non existent god you didn't call them TR7's!!!
Old Feb 22, 2011 | 08:17 AM
  #40
7 Second Club
You'll be safe with that setup.
