2 bar map not registering boost
why is it not recording it in vcm scanner ?
i also have all this codes
p0102
p0106
p0645
p0650
p1637
u1016
b0017
u1040
u1000
Name: 2 bar map
abv: 2 bar
Sensor: Manifold absolute pressure
Untis: Kpa
Function : [AUX.20021]
Or just go down to the bottom where it says EIO inputs and insert 2 bar map.
Now setup your chart page to use the 2 bar map accordingly.
also how can i richen up my idle ? it idles in the 18 range until i give it a little bit of gas and then it goes to 13:1
the car is in open loop and will be staying there
thanks again for the help, this is a great forum, nobody in the hp tuners forum likes to help out.
Sorry for the thread jack elias, just curious about something he said.
Is the offset of 10.33 good on the ls1/6 pcm as well?? we are never sure if the map is reading "correctly" and were wondering about this.
sorry OP
anyway i went to the status display, deleted the sae map sensor
then went insert, used defined,
Name: 2 bar map
abv: 2 bar
Untis: Kpa
did exactly that and when i started the car, it did not show me anything, the 2 bar map stayed at 0 and none of the histograms worked.
what did i do wrong ?
