How much boost on 8.5:1 compression
-what fuel you use
-your fuel system
-whether you mess with alchohol injection
So with a bone stock fuel system you can boost like 4psi.
With a bigger intank and a voltage booster you can run maybe 12psi.
With dual intank or a big external like me you can run 17psi no problem. I think I could probably boost to about 22psi.
Same here.... 8.5:1 comp but on a 383
. I will Cog my D1-SC and shoot for 15-16 psi like Frcefed and BigBos....... Ill be using dual Walbro intanks and -8an line and bigger rails and 59# injecters also.Kyle
