You guys using special gaskets for exhaust manifold to piping?
You guys using special gaskets for exhaust manifold to piping? I'm about to buy this felpro style part number 60988 but not sure if it will hold up to the heat
![](http://www.autopartswarehouse.com/images/apw_products/thumbs200/felpro/60988.jpg)
Took my turbo piping off today. Found out why I blew my percy's carbon gasket apart was probably because one bolt had backed out and the connection was just a bit loose. All that was left of the gasket was a half an inch section. Don't know where the rest of the gasket went but hopefully nothing hit the turbo. Turbo acts normal as far as I can tell.
I thought using rtv was getto but sounds like its not if all you guys like doing it. What is the copper rtv like when it drys? Is it just like a metal copper gasket after it drys or is it rubbery like other rtv products. Is it hard to clean off? Is it possible to damage the turbo if it flakes off?
