My Precision 76mm turbo build
Old 10-02-2010, 02:58 PM
  #61
Greg@RET's Avatar
Originally Posted by ReApEr75
I don't know if you said this or not but im just curious, where you getting your black coolant, oil, and other lines from?
XRP is up the street from the shop.... it hurts every time I walk out of there lol
Originally Posted by badmfkr
how doe's the fuel line connect to the rail?
I see the exhaust out the fender. why did'nt you use the ebay down pipe for a street car?
doe's the motor torque any w/ soild mounts (Move like with rubber mounts) just curious w/ you'r connectorless
cold pipe if rubber mounts where used would the MAF crack due to motor movement?
I like the cold side won't ever have to worry about an IC pipe connector blowing off.
did you relocate the fuse boxs where the air pump was?
The fuel comes in from the back, then goes out from the back. I didnt like their Downpipe, needs to be bigger. Shouldn't move with the solids, but with the intercooler and piping on a street car its good to have something that moves. You can see I have a bar from Vibrant welded on the pipe that quick disconnects. The fuse box is where it usually is, just on the bottom side.
Thanks for the comments guys, picking the trans up on Monday...
Old 10-04-2010, 06:16 PM
  #62
Greg@RET's Avatar
Picked up the Mikes TH-400, reverse valve body, transbrake, SFI flexplate, and bellhousing. Will pick up the Continental Convertor later this week.
Old 10-04-2010, 08:29 PM
  #63
trans2000am's Avatar
i thought you cant weld AN fittings on stock water pumps?
Old 10-04-2010, 08:33 PM
  #64
gsxr1k2's Avatar
What flex plate is that?
Old 10-05-2010, 06:03 PM
  #65
Greg@RET's Avatar
Long as you can weld it you can.
I am not sure, I will ask Mike.
Turbo kit is officially finished. Wastegate piping is on and routed back to the down pipe.
Old 10-06-2010, 06:54 AM
  #66
CarsandWomen's Avatar
how bout a few more pics of that downpipe? i like it, where are you gonna get a bezel to protect the bumper?
Old 10-06-2010, 01:34 PM
  #67
PadenAlbin's Avatar
Amazing attention to detail. Great build!
Old 10-06-2010, 03:24 PM
  #68
MillsMotorvation's Avatar
Nice, and clean. Can you give more info on the turbo?
Old 10-06-2010, 04:06 PM
  #69
Greg@RET's Avatar
I have a ring on the inside and outside of the bumper where the pipe exits. I will try and get some more shots up of the DP.
Thank you.
Precision 76mm, ball bearing with a .96 a/r
Old 10-06-2010, 05:09 PM
  #70
Tally TransAm's Avatar
that engine bay is beautiful man
great job
Old 11-02-2010, 05:14 PM
  #71
deeloc1's Avatar
Any updates??? Dyno #'s etc...?
Old 11-02-2010, 07:50 PM
  #72
Fondle's Avatar
what kind of power can be made with the precision 76? When are you expecting to have it spooled?
Are you running a boost controller or just going off the wastegate spring?
Old 11-03-2010, 11:25 PM
  #73
Greg@RET's Avatar
Any updates on the turbo car? #'s?
Kind of fell by the wayside, I still need to go pick my convertor up. Been busy with customers cars and getting my race car ready for PSCA... Heres the newest toy for that... 2 of them.
Should make 650 on pump with the auto. Just a spring, no controller.
Old 11-04-2010, 10:12 PM
  #74
blown90camaro's Avatar
if you dont mind how much do you recon uve spent so far on this beast? im bout to start my build and would like to know what im getting in to..awesome awesome build btw..
Old 11-06-2010, 02:13 PM
  #75
AzShadow's Avatar
http://www.youtube.com/watch?v=HFGC5BaHJeI
Thats some win right there
Old 11-08-2010, 01:14 PM
  #76
Greg@RET's Avatar
I try not to think about it lol I had $11k in the car as a roller (car, paint, rear, suspension), $5k in the turbo set up, $3k in the trans, motor was sponsored, and another $3k in misc.... easy lol
Old 11-24-2010, 08:18 AM
  #77
11 Second Truck Club
JJ_TURBO's Avatar
Nice built, everything looks real clean. Whats the a/r on the 67billet?
Old 11-29-2010, 12:29 PM
  #78
freakyfastlsx's Avatar
car looks great man keep up the hard work
Old 12-08-2010, 01:48 AM
  #79
1fastlsx's Avatar
awsome set nice work it good to see some one take pride
Quick Reply: My Precision 76mm turbo build
