Night Ryders 106mm build
the crank will hold for what i will be running. not going to get extremely crazy, as the heads and tranny are holding me back.
E98 actually helps keeps everything cooler as it take 30 percent more fuel. same thing for alcohol car. they dont need a intercooler even at 30lbs as they use 50% more fuel. the more 80 degree fuel (or however hot it is that day) you dump in the cylinders the cooler the air gets, and the more heat is absorbed. i am not going to build tons of heat as its only 10lbs. if it was 30lbs it would be a bit different.
