meth and nitrous At the same time?
Hi guys i have PROCHARGER F1C 18 psi i want to know can i run meth and nitrous At the same time? ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
I was thinking, The meth nossle has to be installed before the TB but after the AIT sensor , Does this place right?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
where do you put the nossle for the Nitrous?
thanks to advice![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
thanks
navy
thanks to advice
thanks
navy
Restricted User
Yes you can but i wouldn't. You should spray both before (but not at) the IAT if you want to see actual charge temps. The point of the IAT is to correct for actual charge temps. Once you have it all wired in and working correctly, take it out and hit it on a hot day. This will give you the hottest IAT temp data point. Once you know that, you can make the IAT pull timing at WOT if it is hotter than your data point. This will give you some safety in the likely event that one or both do not work properly so that you dont blow your **** up.
Be intresting to see what the IAT would be with both meth and N2O spraying! ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Could you not just use a wet N2O kit and use meht as the fuel? obviously you would have to use the correct jets for the meth and maybe a little bigger still?
Chris.
Chris.
