Hissing noise when I hit boost
Old Aug 22, 2010 | 02:18 AM
22lambo's Avatar
Default Hissing noise when I hit boost
If I am driving with the windows down and I WOT it, I can hear a hissing noise and sounds like it is coming from the diver side which is where my BOV is. Could it be the BOV is leaking under boost? Also I am running 5 lbs. Checks all the clamps and everything and all seems good. Thanks.
Old Aug 22, 2010 | 09:44 AM
TurboAv's Avatar
Where ie your wastegate at? Did you actually pressure test the piping?
Old Aug 22, 2010 | 12:09 PM
22lambo's Avatar
Doesn't have one, it's supercharged. No did not pressure test it.
Old Aug 22, 2010 | 12:17 PM
kbracing96's Avatar
It's probable the air being sucked into your compressor.
Old Aug 22, 2010 | 01:46 PM
22lambo's Avatar
Could be. Either I have never noticed it or it has just started happening.
Old Aug 22, 2010 | 02:33 PM
JAX04's Avatar
THis, and you cannot know if your piping is leaking without air testing it, lol. Calmps may look fine, but is not always the case.
i mustve went over all my clamps 10 times trying to find leak. They seemed perfect until i put 12lbs of air in my system. i found 4 leaks that couldve sworn were the best looking sealed joints on my setup.
do yourself a favor and airtest that system
Old Aug 22, 2010 | 03:11 PM
22lambo's Avatar
You convinced me haha so how did you test your air system?
Old Aug 22, 2010 | 05:16 PM
98Z28CobraKiller's Avatar
Restricted User
If you had a leak, you'd be losing boost. If you are building the same boost as always, no leak.
Old Aug 23, 2010 | 02:01 AM
22lambo's Avatar
Thanks, that answered my question then.
