darton sleeved 427 f1a
I have been running a solid roller setup n/a with the cam specs of (.661 intake 254 dur ) (.668 exhaust 260 dur) with a lsa of 114. My question is this a good blower cam and can i convert the car back to hydraulic roller using this cam?
cam grind is 4876r / 4877r sr 114+2. What intake would you reccomend the vic jr or gmpp? will this elbow from http://www.intakeelbows.com/ fit without cutting my cowling? I cant stand to hack **** up.
My setup is darton sleeved 427,afr 225 heads 70cc, wiesco -32 cc pis,eagle crank,scat h beams. Blower is a f1a 8 rib 15psi fmic .
Dan
Dan
I would run that cam - it's very similar to my SR 250/256 115LSA+4 Comp on a 421" YSi motor. The motor size and blower will make the cam quite workable. What springs are you running, and what valve lash?
Jim
Jim
