Big cc heads vs dished pistons
Old Aug 27, 2010 | 01:53 PM
99SS-T's Avatar
Default Big cc heads vs dished pistons
Question is if it is a bad idea to get bigger cc heads, like 72's, and keep the flat top pistons that i have or get smaller cc heads and buy dished pistons?
Im sure that it is better to get the dished pistons but does it make enough of a difference to take out the flat toppers that i have and buy dished on top of buying the afr's or tea's?
I unfortunately have to take the engine out anyway so this is the time to get it right. The pistons that are in there are forged as it the rest of the engine but I dotn wanna be tearing this apart nemore. And it seems that it is gonna be alot easier to get smaller cc heads off the FS section then it is to find 72's to get the compression lower then the 10 something that it would be with smaller cc.
Thanks!
Old Aug 27, 2010 | 02:08 PM
98Z28CobraKiller's Avatar
Restricted User
I believe that the less dish the better. I have a deep dish because I have a 62cc premium head with additional port work done that I carried over from a nitrous build. It was just a cost thing for me.
Old Aug 27, 2010 | 05:00 PM
Johnv's Avatar
Also gives you a bit more flexability with the engine,
big cc heads for boost and if you decide to go back to NA ,
just bolt some small cc heads back on...
Old Aug 27, 2010 | 05:24 PM
1CAMWNDR's Avatar
Go with a larger cc combustion chamber to start with, then get a dished piston that will give you your desired compression ratio. The bigger/deeper dish you put on a piston the more you are lowering the crown. If you have a stock crank you will have more room in the piston for a dish since the pin will not be as high as on a stroker piston. I'd try to keep dish as minimal as possible.
Old Aug 27, 2010 | 05:48 PM
99SS-T's Avatar
Well i do like to hear that i am not that bad off with flat top pistons. I do have a stock ci forged crank.
How come the pistons are dished vs just lowering the whole piston? Like still be flat top but at the depth of the dish in the dished piston with out the higher sides. If it helps with controllign the combustion then why not have all pistons dished?
Thanks for any info!
Old Aug 27, 2010 | 06:03 PM
slow67's Avatar
Gingervitis Addict
Usually flat top pistons are lighter than dishes, so less reciprocating weight.
Old Aug 27, 2010 | 08:03 PM
Shawn @ VA Speed's Avatar
it's always best to run a piston with the least amount of dish.Flattop pistons are much stronger than deep dished pistons.
