On center T-76
Thanks http://www.photohost.org/gallery/sho...cat=500&page=1
here is a pic
Unless you go up on the A/R, the hot side should be the same size. Even if you do go bigger, the bolt holes don't move. Part of the reason for an on-center housing.
I do plan on laying down the Rad. so I can get more room on the compressor side.
That's part of the reason i've got normal T series stuff on mine, i can upgrade to 76's in the future and maintain the same packaging. Assuming i don't go to a larger exhaust, but even then i left some room to grow
I say call Turbonetics and ask, they should be able to take that one back and make it a 76 for probably pretty cheap. Hopefully it's a big shaft 62, then then can reuse the bearing housing.
I looked at their site. WOW..............but it looks like they don't deal with on-center type turbo's
Thanks Much.....................now all I have to do is see how much CI I can go with this system. I am looking at 382..........but a 427 would be nice as well
