How much fuel
Old Jan 26, 2004 | 11:27 AM
30thta436's Avatar
Default How much fuel
If I am pushing 100 lb/min(1400cfm) of air, How many lbs/min of fuel will I need?
I have a t-rex external booster pump and a stock pump in the tank. I am at 630RWHP now with about 75lbs/min. Just need to know how much fuel I need to get to 800RWHP mark with the T-trim. I think I will be seeing 100lbs/min(1400 cfm). Just need to figure out what type of fuel system. I was thinkin a walbro 341 in tank with the T-rex booster pump.
Any suggestions.
Old Jan 26, 2004 | 12:30 PM
y2khawk's Avatar
Any suggestions.
pair of 340 intanks in parallel, pair of T-rex external in parallel w/ no intank, single weldon 2025 external, or a big aeromotive external.
Choose one
30thta436's Avatar
Another question?
Would I be correct if I assumed:
Since I need fuel for 110lbs/min of air. I could devide the air flow by air fuel ratio (110/11=10). If so I come up with needing a 10lbs/min of fuel flow. I know I would need some extra fuel for spikes and to feed both sides of the fuel rail evenly. So I can surmise one walbro 340 and the t-rex are not going to be near enough. One walbro flows a max of 255liters per hour or 404lbs per hour. If I devide that by 60 minutes I come up with 6.73lbs/per min.
So would twin walbro's in tank without and external pump be enough @ 13lbs/per min combined?
Old Jan 26, 2004 | 12:31 PM
S_J_H's Avatar
The answer is very simple. Simply divide your airflow by the fuel ratio you desire. for a 11.5-1 af ratio- 100/11.5 = 8.695
now convert that into the more common lbs/hr and you get 521.7 lbs/hr.
divide by 8 and you need to flow 65.2lbs per injector.
So figure maybe around an 80lb/hr injector and a fuel pump that flows at least 650lbs/hr IMO.
Old Jan 26, 2004 | 12:32 PM
30thta436's Avatar
Choose one
You posted while I was typing my second respone. Can you look at my second post and see if I am on the right track. If so Is 3lbs per minute enough reserve?
Thanks
Old Jan 26, 2004 | 12:33 PM
S_J_H's Avatar
oops I did my calcs for 100lbs/min
Old Jan 26, 2004 | 12:35 PM
S_J_H's Avatar
I was figuring components operating at about 80% of max.
Old Jan 26, 2004 | 12:36 PM
30thta436's Avatar
You posted while I was typing also. Thanks for the info. Thats kind of what I was thinking. I have 50lb injectors in there now. It was running very rich. I took 40% out of the pe table to get 12:1 afr at 630RWHP. So I was thinking that I have plenty of injector left.
You say I need 65lbs per hour injectors. The 50lbs I have now are rated at 43.5 PSI fuel pressure. What does that equate to at our 60PSI fuel pressure.
Old Jan 26, 2004 | 12:38 PM
Blackbird's Avatar
Old Jan 26, 2004 | 12:40 PM
red ws6 99's Avatar
Any suggestions.
Take your 100 lb/min divide by the Air to fuel ratio multiply by density of gasoline multiply by 60 convert to gallons to liters.
So 100 lb/min / (AFR=12) = 8.33 lb/min fuel
8.33 lb /min * (Density =1 gallon/6 lb) = 1.38 gallons/min
1.38 gallons/min *60 min = 82.8 gallons/h
82.8 gallons/h = 313 liters/h
So the engine will ingest 313 liters/h, however, this is not the size pump you need.
This number assumes that all the gasoline pushed/pulled by the pump goes into the engine. Some has to go to the return line (from the fuel pressure regulator) otherwise you have no pressure control. Also since you are boosted if your fuel pressure goes up one psi for every psi of boost, the pump output drops.
So basically a walbro 340gs (255 lph) and inline is not a good idea. Walbro 340gs is good for maybe 500 rwhp the inline cant really add much more than that just helps with pressure drop.
Gary
Old Jan 26, 2004 | 01:34 PM
S_J_H's Avatar
I was using 6.2lbs for weight of 1 gallon of gas.
Old Jan 26, 2004 | 02:18 PM
smokemup's Avatar
Total airflow requirements:
1415.92 cfm
106.38 pounds of air.
7.22 pounds of fuel
Fuel Supply requirements:
1.2 gallons per minute for 14.7 A/F ratio.
92.5 gallons per hour for 11.5 A/F ratio.
350.11 liters per hour for 11.5 A/F ratio.
airflow calc
Old Jan 26, 2004 | 02:33 PM
30thta436's Avatar
Would dual 255 walbro's in the tank work ok?
What size an line should I use to get from the tank to the rail?
Old Jan 26, 2004 | 02:57 PM
cablebandit's Avatar
excuse the ignorance and my mistakes right off the bet I thought 100 lb/min maf flow equals 1000 rwhp. Now I have some measurement wrong but I could always translate my autotap reported maf flow directly to rwhp. It would correlate on the dyno every time. What am i missing? I THINK Harlan was getting the same correlation when he JUST had 600 rwhp on his stock motor/maf and incon. Please teach a brothah!!!
Old Jan 26, 2004 | 03:10 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I am making 720-746rwhp thru a T400 that's 800rwhp for sure thru an M6, I have 83 lb injectors and a Weldon 2025 pump set at 42psi.
Old Jan 26, 2004 | 03:18 PM
y2khawk's Avatar
Choose one
a pair of 255l/hr pumps will flow 120+ g/hr of fuel, a single 340 is good to nearly 60g/hr with a good hot wire supply.
figure minimum -8 feed, -6 return. I prefer -10 feed and -8 or -10 return depending on the pump setup.
1 lb/min of air ~= 10hp, so 100 ~= 1000 FWHP, give or take a few
Old Jan 26, 2004 | 07:59 PM
NA$TY-TA's Avatar
So what your saying Matt is that two Walbro 340's are good enough for over 800rwhp and -8 feed and -6return will support it???
Will 57# @3 bar or 66# at 4 bar be enough to support 700 rwhp?
Old Jan 26, 2004 | 08:33 PM
How would harlan know...he is only running a t-66
Old Jan 27, 2004 | 06:45 AM
y2khawk's Avatar
you can do it, i personally would like to see a -10 feed though. We're running a twin 340, -8 feed, -6 return setup on a twin 60-1 LT1, it's over 700rwhp on the good old mustang dyno and the fuel system hasn't missed a beat.
The pumps will supply plenty of fuel, over 1000HP worth at 70 psi or so, but I'd personally go to the bigger feedline if I was pushing them that far. A bigger return is a good idea if you plan to run both pumps all the time. Otherwise you might get into pressure creap at idle when trying to bypass most of that fuel back to the tank. I run a -10 return a still see a jump in fuel pressure when i switch to high speed on the pump at idle, just not enough return flow through the regulator and line.
a 66 lb/hr injector, assuming you use a referenced regulator, should be able to supply enough fuel for about 770 FWHP at 80%, and about 960 at 100%. With an auto in the car, they will just be on the edge depending on how rich you want it. I was figuring .55 BSFC which is pretty normal for boost.
Old Jan 27, 2004 | 11:51 AM
LS1Tech Co-Founder
I am running:
Weldon 2025
Seimens 83 lb injectors
Weldon regulator, 43 psi at idle
FAST system
-10 feed, SS Racing fuel rails, -8 crossover and -6 return.
Aeroquip fittings
