6.125" vs. 6.3" rod pros/cons?
I found a set of used Oliver 6.3" rods for a good price that would be paired up with a stock crank. Is there any advantage to running these vs. a standard 6.125" length rod which most people run?
What are the pros/cons? I want to spin the motor to around 7200rpm redline. Single turbo setup.
You havent mentioned the most important part...what stroke do you want to run ?
You've no mission with a 4" stroke Even with stock stroke it would be tight.
