Is my setup missing anything?
Building a front mount setup on my 98 formula, so far I have
Front mount kit from LS1Silverado05 as seen here:
https://ls1tech.com/forums/parts-cla...turbo-kit.html
- A Master Powers MP T70 .96 Turbo
- A 38mm Tial Wastegate
- A 50mm Blow-Off Valve
- An Oil Feed & Drain Kit
- Non-EGR Truck Manifolds
- Standard Truck Flanges and T4 Flange
- Mandrel Bent Fabricated 2.5" Merge Pipe, and 3" Downpipe Wrapped
- 3" Intercooler and Cold Pipe
- Hallman Pro Boost Controller
- A-Pillar Gauges (Fuel,Boost,Trans)
And separately I have:
- 01 5.3 shortblock
- 317 heads
-.053 MLS gaskets
- Hardened pushrods
- PRC single beehives .600 lift
- LS6 ported oil pump
- Racetronix 98 in tank single 255 with hotwire kit (this will be upgraded after I get the car up)
- 60lb injectors
- GM 2bar MAP
- LS2 timing chain
- ARP head bolts
Other than the usual gaskets and bolts that I will need, I think I have it covered. I plan to run it probably 6-7 PSI for a while until I get it well tuned and upgrade the fuel system further, but I can't afford the kind of fuel system I want right now so it has to wait.
if you dont have the money then rock the bolts until you can get the studs
