turbo map question for twins
Old Sep 16, 2010 | 10:02 PM
IKnowtheFuture's Avatar
Question turbo map question for twins
ok. so if a turbo map says at 2.0 pr it flows 50 lbs/min you multiply it by two and get 100 lbs/min that it'll flow with both turbos into the motor right? so hypothetically 1000 hp at 15 lbs correct?
Old Sep 16, 2010 | 10:23 PM
TurboS10's Avatar
Correct
That would be 2 61mm turbos or some of the 58mm's.
You want that flow to be at least in the 65% efficiency area on the map.
With t61's it would be in the 70's.
Old Sep 16, 2010 | 10:29 PM
thanks. i was looking at holset maps
