Water Vapor Collection system
Again, I stress the 'guessing' strategy as I'm trying to learn here, not make statements of authority or certainty.
Is this setup, Kurt's in particular, something that could help save the ringlands on the back cylinders?
I have a FAST intake, and as such, had to block off the rear vent tubes, and last weekend I think I cracked #7's ringland.
Kurt, I'd like to hear your thoughts on this as I'm going to go with a forged shortblock, but I want to avoid this situation from ever happening again.
Thanks
Kurt
At the time I already had the ls6 crossover tube and picked up the ls1 tube locally for next to nothing, so for now it should help alleviate cyl 7/8 temp spikes/hot spots from trapped air. I think the coolant path is more at fault here though.
also, is there an advantage to running this over a factory 4 corner setup? right now my motor as it came with the car a year ago n/a had the rears with blockoffs on them and now with going fi and reading this, i'm concerned about the hot spots.
lastly, will your kit or the factory 4 post setup work with a vic jr without issue?
A vic Jr. sits pretty high above the valley cover, so I don't see it being an issue with either.
Kurt
Kurt
