What Piston Rings for a boosted 370??
Old Sep 22, 2010 | 01:16 PM
01 BERGER CAMARO SS's Avatar
Default What Piston Rings for a boosted 370??
Im builting a boosted 370 and am debating what piston rings to use...Im going to order from speedinc. Motor will be fully built with ported 243 heads and a tvs1900. Im between "Diamond Pro Select Piston Rings" and "Total Seal Advanced Profiling Rings" Im not going to be boosting over 10lbs but might spray it with meth..What do you guys runn?
Old Sep 22, 2010 | 03:14 PM
LS1NOVA's Avatar
Hellfire
Old Sep 22, 2010 | 03:24 PM
blue00ZZleeper's Avatar
hellfire
Old Sep 22, 2010 | 03:55 PM
98Z28CobraKiller's Avatar
Restricted User
The Wiseco pistons come with the correct rings.
Old Sep 22, 2010 | 06:56 PM
ok, i found hell fires in the summit catalog.. They are Piston Rings, Ductile Iron, 4.030 in. Bore, 1/16 in., 1/16 in., 3/16 in. Thickness, 8-Cylinder.. Would those be it?
Brand Sealed Power
Manufacturer's Part Number ZR1910035
Part Type Piston Rings
Product Line Sealed Power Hellfire Piston Ring Sets
Summit Racing Part Number SLP-R-19100-35
Bore (in) 4.030 in.
Bore (mm) 102.489mm
Top Ring Included Yes
Top Ring Thickness 1/16 in.
Second Ring Included Yes
Second Ring Thickness 1/16 in.
Oil Ring Included Yes
Oil Ring Thickness 3/16 in.
Oil Ring Tension Standard
File Fit Yes
Gapless No
Top Ring Material Iron
Top Ring Facing Material Ductile iron
Second Ring Material Iron
Second Ring Facing Material Cast iron
Oil Ring Material Stainless steel
Quantity Sold as a set.
Old Sep 23, 2010 | 07:52 PM
jrocstar's Avatar
yes. hellfire all the way
Old Sep 23, 2010 | 08:19 PM
helicoil's Avatar
Brand Sealed Power
Bore (in) 4.030 in.
Bore (mm) 102.489mm
File Fit Yes
Gapless No
Yes, that is a Hellfire p/n. Be certain that your piston accomodates a std. D-wall radial thickness dimension
