help with turbo size
Old Sep 22, 2010 | 04:30 PM
skinumback's Avatar
Default help with turbo size
6.0 iron block 317 heads 9.1 static stock stroke, 240 240 cam, blow through carb, th400 3500 converter, going into 93 silverado. Looking for around 800 flywheel Hp. Going to use stock drivers manifold and custom header, crossover and down pipe. All the help on turbo sizeing I can Get will be greatly appreciated! Thanks, oh yea this is on Gas, not E85
Old Sep 22, 2010 | 04:36 PM
98Z28CobraKiller's Avatar
Restricted User
I think you are a perfect candidate for one of those S480's.
Old Sep 23, 2010 | 12:05 AM
BottleFedZ346's Avatar
That or a PT88 should do the job!
