pro charger
Old Sep 24, 2010 | 01:47 PM
slolt1's Avatar
Default pro charger
would a set of 64cc 5.3 heads work with a procharger or would it be to much compresion
Old Sep 24, 2010 | 01:52 PM
NemeSS's Avatar
used on what engine?
Old Sep 25, 2010 | 01:34 PM
fatmat80's Avatar
if its a stock bottom end ls1 i would say yes.. you are gonna be hancuffed on ho much boost you can run safely.
Old Sep 26, 2010 | 01:16 AM
slolt1's Avatar
yes its stock ls1 bottom end
Old Sep 26, 2010 | 10:50 PM
blue00ZZleeper's Avatar
Yea I wouldnt run them. Compression will be to high to run anything more then 6 or 7 psi. Your better off going with 317 heads because they'll drop compression from 10.1-1 to 9.6ish-1
Old Sep 26, 2010 | 11:03 PM
MR2liter's Avatar
How much boost are you trying to run? If you are planning on running less then 10 I would say run the 5.3s as you will make more power at less boost. Anything over 10psi I'd suggest going with the lower compression 317s. Good luck and run meth for sure!
Old Sep 27, 2010 | 01:11 PM
fatmat80's Avatar
i forgot to add that in my post meth will be your bff!!! i would say use the 317s.
