Need piston and rod help for 6.0 with milled 317 heads..need lower compression
im gonna be putting together a 6.0 and need some help with rotating assembly. im putting together a standard bore lq9 motor. i got a nice set of ported 317 heads but they were milled .030 and were set up for 11.5 compression with a 5cc piston i was told. what rod and pistons do i need to get in order for my compression to come in around 9.3ish area? car will be ran on meth and a decent amount of boost. thanks for any help in what direction i need to go to make these heads work.
